Overall developments and widespread public awareness of man-made climate change are transforming the way people think. The awareness has inspired a shift towards a more ecologically sustainable way of life. Driven by policymaking and technological innovation, ambitious efforts are underway to reduce greenhouse gas emissions to curb the rise in average temperatures. A key focus of these efforts is the mobility sector.
Weiler Abrasives has announced its new blending disc product lineup that is ideal for a wide range of blending, weld cleaning and polishing needs. The blending discs can help operations save time and money through faster material removal and longer product life in such applications as shipbuilding, structural fabrication and welding.
The world of bevel gear grinding is a complex topic. How do you determine which grinding and dressing parameters to select for a desired surface finish? What type of grinding wheel should be used? What type of dresser should be used? How do all these factors affect the gear noise and quality levels? These are some questions that will be addressed in this article.
The Curvic coupling from the aviation sector is a critical component used in helicopters. Previously, the external helical gearing was manufactured on one machine and the curvic coupling gearing on a second machine. The external and internal cylindrical grinding was then carried out on a third machine in two consecutive process steps.
From the outside, Gallmar Industries, nestled into an Oshkosh, WI, neighborhood, looks like any unassuming, medium-sized gear shop. Then take a plant tour with Gallmar’s VP of Operations Kenan Zolota—and prepare to be amazed. The facility stretches on like the Army’s warehouse at the end of Raiders of the Lost Ark, with everything from gear cutting to heat treat, gear grinding to inspection, all under one roof. Gallmar’s breadth of product line is in evidence too: defense-related transmission gears, 60-in. diameter internal gears for mining equipment, axle components for fire/ rescue trucks five feet in length, right down to a bin of brass ammunition casings that Zolota says are a special order.
UK-based PTG Holroyd has announced that, in the future, all models in its TG Series of ultra-precise helical rotor and thread grinding machines will be equipped with the Siemens digitally native Sinumerik One CNC as standard.
UK-based PTG Holroyd has announced that going forward, all models in its TG Series of ultra-precise helical rotor and thread grinding machines will be equipped with the Siemens digitally native Sinumerik One CNC as standard.
For over 10 years, the mechanical engineering company Kapp Niles has been working intensively on the topic of gears in e-mobility and has established itself as a pioneer in this rapidly growing industry. With a focus on innovation and quality, Kapp Niles offers customized solutions for the production of gearboxes and gears in electric vehicles.
Nidec Machine Tool Corporation (“Nidec Machine Tool” or the “Company”), a group company of Nidec Corporation, today announced that it has developed the a high-accuracy polishing (grinding) method to machine internal gears for mass production that are used for automobiles’ drive units and transmissions and robots’ joints. While there are already high-accuracy polish-machining methods for external gears for mass production, no such methods have been available for internal gears. After conducting research focused on this point, the Company has achieved positive results in securing the level of accuracy and production that conventional grinding, honing, or skiving methods could not.
This article introduces the process of polish grinding of gears. Improved surface quality increases the overall efficiency of gearboxes, resulting in reduced friction and torque loss, higher power density, and noise-optimized gears (lower NVH); all these factors are highly relevant, especially for electric drives. When Reishauer developed polish grinding in 2012, the process aimed to improve the efficiency of ICE engine transmissions, and the set goals were easy to achieve. Today, in 2023, the situation is dramatically different. While an ICE engine operates at around 3,000 rpm and supplies acoustic masking of the gear noise, EV drivetrains feature up to 20,000 rpm and offer no such masking.
