Another young man discovers you need not be an expert machinist to succeed as a gear engineer. Spoiler alert: never tangle with a grinding wheel; they are undefeated in all time.
This paper outlines the basic principles of involute
gear generation by using a milling cutter;
the machine and cutting tool requirements; similarities
and differences with other gear generative methods; the cutting strategy; and setup adjustments options. It also discusses the applications that would benefit the most: for coarse-pitch gears the generative gear milling technologies offer improved efficiency, expanded machine pitch capacity, decreased cutter cost, and a possibility for reducing the number of machining operations.
