Nagel and Gehring recently shared innovative technologies during AMB 2022 including new standards in efficient honing, maximum flexibility in the superfinishing of flat, concave, and spherical surfaces, and efficient internal and external honing of workpieces.
To increase cost efficiency in wind turbines, the wind industry
has seen a significant rise in power density and an increase in the overall size of geared components. Current designs for multimegawatt turbines demand levelized cost of energy (LCOE) reduction, and the gearbox is a key part of this process. Since fatigue failures nearly always occur at or near the surface, where the stresses are greatest, the surface condition strongly affects the gear life. Consequently, an improved surface condition effectively avoids major redesign or increased material cost due to an increase in part size. Additional finishing methods such as shot peening (SP) and superfinishing (SF) significantly increase the gear load capacity, but these effects have not yet been adequately considered in the current ISO 6336 standard or in any other gear standards. The combination of SP followed by SF will be described here as an “improved gear surface” (IGS).
Oil-out conditions, or conditions
in which an aircraft is
operating without any oil in its
gearbox or transmission, are
devastating for an aircraft's
hardware. Even the sturdiest gears
usually can't last 30 minutes under such
conditions before they catastrophically
fail, and the whole system usually follows shortly after. That doesn't leave pilots with a whole lot of time to find a suitable location to land in the case of an oil-out emergency.
Following is a report on the R&D findings regarding remediation of high-value, high-demand spiral bevel gears for the UH–60 helicopter tail rotor drivetrain. As spiral bevel gears for the UH–60 helicopter are in generally High-Demand due to the needs of new aircraft production and the overhaul and repair of aircraft returning from service, acquisition of new spiral bevel gears in support
of R&D activities is very challenging. To compensate, an assessment was done of a then-emerging superfinishing method—i.e., the micromachining process (MPP)—as a potential repair technique for spiral bevel gears, as well as a way to enhance their performance and durability. The results are described in this paper.
