This letter is in response to your article
asking the readers where their interests
lie. The division of Rockwell International where I work has engineering departments in Cicero.
Much information has been written on gear inspection, analytical. functional. semiautomatic and automatic. In most
cases, the charts, (if you are lucky enough to have recording
equipment) have been explained.
This article describes a new technique for the size determination of external Involute splines by using a span measuring method. It provides application performance information
demonstrating how this method and its
measurements correlate with the traditional spline ring gage sizing method.
In the field of large power transmission gear units for heavy machine industry, the following two development trends have
been highly influential: use of case hardened gears and a branching of the power flow through two or more ways.
An expression is derived, giving the optimum number of teeth over which the span measurement should be made, for profile-shifted spur and helical gears.
Presumably, everyone who would be interested in this subject is already somewhat familiar with testing of gears by traditional means. Three types of gear inspection are in common use: 1) measurement of gear elements and relationships, 2) tooth contact pattern checks and 3) rolling composite checks. Single Flank testing falls into this last category, as does the more familiar Double Flank test.
