years ago.
The October 2011 issue of Gear Technology featured the article “Low-Distortion Heat Treatment of Transmission Components,” which covered
the combination of low-pressure
carburizing and high pressure gas quenching in an automotive environment. Here, heat treating expert Dan Herring explains why oil quenching is an appropriate choice for many applications.
