Metrology is a vital component of gear manufacturing. Recent changes in this area, due in large part to the advent of computers, are highlighted in this article by comparison with more traditional methods.
March 19-22, 1989. first International Applied Mechanical Systems Design Conference. Convention Center, Nashville, TN.
March 28-30, 1989. Gear Design Seminar, University of Northern Iowa
In the field of large power transmission gear units for heavy machine industry, the following two development trends have
been highly influential: use of case hardened gears and a branching of the power flow through two or more ways.
