In today's production environment, a variety of different measurement devices is used to assess the quality and accuracy of workpieces. These devices include CMMs, gear checkers, form testers, roughness testers, and more. It requires a high machine investment and a high handling effort - especially if a full end-of-line measurement is needed. One approach to reduce quality costs is to include all measurements in one single machine that is suitable and robust enough for use in production.
Alongside the macro test parameters on tooth flanks for profile and tooth traces, surface
properties (roughness) play a decisive role in ensuring proper toothed gear function. This
article addresses roughness measurement systems on tooth flanks. In addition to universal
test equipment, modified test equipment based on the profile method for use on gears is
addressed in particular. The equipment application here refers to cylindrical gear flanks and
bevel gear flanks. The most important roughness parameters, as well as the implementation
of the precise measurement procedure will also be described under consideration of the
applicable DIN EN ISO standards as well as the current VDI/VDE Directive 2612 Sheet 5.
In earlier studies, surface roughness has been shown to have a significant influence on gear pitting life. This paper discusses how high surface roughness introduces a wear mechanism that delays the formation of pits. Accompanied by a full-page technical review.
