Take 10% off Chain, & Pushers for IQF Furnaces, and 10% OFF Fans for IQFs, Tempers and Carbottoms from July 26 to August 26, 2017. Call (815) 636-7855, ext. 224 to place your order. Excellent Prices and Great Service — Building Heat Treating Solutions Your Company Can Afford.
When sending gears to be heat treated, manufacturers can end up unwittingly making mistakes that slow down turn-around time. We talked to some heat treaters to get their best advice on how you can help them help you.
This customer was relocating their existing facility to a new location so they could continue to grow and advance. As such, any new equipment they chose needed to be able to handle the everyday range of requests, from different processes and part geometries to different load sizes. Read the customer story.
New continuous vacuum furnace from SECO utilizes low-pressure vacuum carburizing in combination with 4-D® high-pressure gas quenching. Every part is heat-treated in an identical manner using the same process parameters and part movement, resulting in consistent, repeatable, high-quality parts.
Vacuum gas nitride processing from Solar Atmospheres can significantly increase the fatigue strength and service life of your parts. Benefits include case depths up to 0.025" and improved wear and anti-galling properties due to a 40 - 70% increase in surface hardness. Corrosion resistance is increased through nitrogen-enrichment.
Barkhausen Noise Analysis is a non-destructive testing solution for grinding burn detection, case depth measurement, heat treat defect detection, and residual stress measurement. Discover how this alternative method can improve your quality inspection process. Download the info sheet now!
When sending gears to be heat treated, manufacturers can end up unwittingly making mistakes that slow down turnaround
