Seco/Warwick Introduces Super IQ Furnace to North American Market October 8, 2019 Seco/Vacuum Technologies, Seco/Warwick Group’s company, is pleased to introduce to the North American market Super IQ (integral que...Read More
Scheuring Joins Solar Atmospheres as Plant Metallurgist September 24, 2019 Solar Atmospheres announces the addition of Gregory Scheuring as plant metallurgist. Scheuring is a graduate of the University of Pittsbu...Read More
Grieve Universal Oven Offers Variety of Heat Treatments September 4, 2019 No. 841 is a 650°F (343°C), universal oven from Grieve, currently used for a variety of heat treatments at the customer’s f...Read More
Influence of Thermal Distortion on Spur Gear Tooth Contact September 1, 2019 In this paper the effects of thermally induced geometry distortions on load distribution and transmission error have been analyzed.Read More
Heat Treat Expo 2019 Booth Listings September 1, 2019 Map and listings of the ASM Heat Treat Expo 2019.Read More
Get Answers LIVE and in Person September 1, 2019 You have challenges. We all do. If your challenges are related to any aspect of gear design, manufacturing, inspection, heat treating or use, the solutions can be found at Motion + Power Technology Expo, which takes place October 15–17 in Detroit.Read More
Starrett Expands Hardness Testing Line August 30, 2019 The L.S. Starrett Co. has significantly expanded its line of Benchtop Hardness Testers, adding seven Rockwell systems, eight Vickers syst...Read More
Klüber Lubrication Offers Heat Transfer Oils for Open or Closed Heating and Cooling Systems August 29, 2019 Klüber Lubrication, a worldwide manufacturer of specialty lubricants, introduces heat transfer oils for use in open or closed heatin...Read More
Appreciating the Gory Details August 29, 2019 Charles D. Schultz No Comments Big equipment often requires special processing equipment. Those 300-ton locomotives used unique heat treatment on the gears which required the des...Read More
Gear Origins: Roman Cisek August 13, 2019 Charles D. Schultz No Comments I was lucky to get a job as a design engineer – drive train department with a big construction equipment manufacturer (HSW) in Poland, right after ...Read More
