Barkhausen Noise Analysis is a non-destructive testing solution for grinding burn detection, case depth measurement, heat treat defect detection, and residual stress measurement. Discover how this alternative method can improve your quality inspection process. Download the info sheet now!
Learn how customers increased their analysis accuracy and repeatability, and cut costs by reducing scrap and eliminating the need for chemical disposal. This non-destructive testing method for grinding burn detection and heat treat defect detection improved product quality and resulted in significant cost savings.
Vacuum gas nitride processing from Solar Atmospheres can significantly increase the fatigue strength and service life of your parts. Benefits include case depths up to 0.025" and improved wear and anti-galling properties due to a 40 - 70% increase in surface hardness. Corrosion resistance is increased through nitrogen-enrichment.
For gear heat treaters seeking an exceptionally high quality nitriding and ferritic nitrocarburizing solution, SECO/WARWICK's innovative ZeroFlow® process reduces operating costs and offers improved quality of the resulting nitrided layers. Click to learn more.
