Enhance your atmosphere heat treatment operations with the latest industry innovations and technical resources. Take a close-up look at the inner-workings of the ATLAS batch atmosphere furnace line with the walkaround video, or read the technical article on enhancing your carburizing and quenching processes. Click here to access these resources.
True single-piece flow surface hardening of gears is now available. One-at-a-time vacuum heat treatment of gears followed by one-at-a-time high pressure gas quenching results in before-unheard-of gear consistency. Eliminate high variability of product within a load by using SECO/WARWICK’s all-new UniCase Master vacuum furnace for high-volume gear manufacturers.
Contact Michael Lister, Michael.lister@secowarwick.com, 814-853-6672.
Receive a close-up look at the ATLAS atmosphere furnace line, which delivers intelligent interfaces, advanced controls and ease of integration. The ATLAS walkaround video showcases the inner-workings of the heat zone, combustion system, quench tank, controls, loader and … Watch the video here.
Effective case depth is an important factor and goal in gas carburizing, involving complicated procedures in the furnace and requiring precise control of many thermal parameters. Based upon diffusion theory and years of carburizing experience, this
paper calculates the effective case depth governed by carburizing temperature, time, carbon content of steel, and carbon potential of atmosphere. In light of this analysis,
carburizing factors at various temperatures and carbon potentials for steels with different
carbon content were calculated to determine the necessary carburizing cycle time.
This methodology provides simple (without computer simulation) and practical guidance
of optimized gas carburizing and has been applied to plant production. It shows that measured, effective case depth of gear parts covering most of the industrial application range (0.020 inch to over 0.250 inch) was in good agreement with the calculation.
