Solar Atmospheres in Souderton, PA, recently commissioned a new vacuum furnace capable of utilizing high-pressure gas quenching at 20-Bar (about 300 PSI) to meet demanding cooling rate specifications for the heat treatment of nickel-based superalloys.
VBN Components AB in Sweden manufactures extremely wear-resistant materials and is known for "the world's hardest steel," Vibenite 290, and "the world's first 3D-printed cemented carbide," Vibenite® 480. VBN's new heat treatment machine, a so-called URQ-HIP (Uniform Rapid Quenching-Hot Isostatic Pressing), was recently inaugurated at the company.
Press quenching technology for more hardening consistency, improved operator efficiency, and faster throughput of a wide range of gears and other close-tolerance cylindrical components
Press quenching is a tried-and-true process for the controlled hardening of flat, circular close tolerance parts. The process ensures good dimensional control and uniform hardening, thus allowing for seamless processing post heat treatment.
Quality control, EV components, energy consumption and material influences are just a handful of topics being discussed in heat treating today. New heat treat methods and global trends will be the topic of conversation later this year at Heat Treat 2023. Here’s a round-up of some stories circulating across key market segments.
Solar Atmospheres of Western Pennsylvania is pleased to announce the approval of a critical Boeing specification for the oil quenching of alloy steels in accordance with Boeing’s specification BAC 5617.
Solar Atmospheres of Western PA successfully vacuum heat treated two massive H13 extrusion dies at their Hermitage PA facility. Their newest high performing Solar Manufacturing 10-Bar 600 Horsepower high pressure gas quench vacuum furnace was able to fully harden two huge H13 extrusion dies in successive cycles.
A newly designed Vacuum Oil Quench (VOQ) furnace, purchased by Solar Atmospheres of Western PA, recently entered into full production after passing a vigorous start up protocol.
"How sir, would you make a ship sail against the wind and currents by lighting a bonfire under her deck? I pray you, excuse me; I have not the time to listen to such nonsense."
