Carburized gears have higher strengths and longer lives compared with induction-hardened or quench-tempered gears. But in big module gears, carburizing heat-treatment becomes time-consuming and expensive and sometimes cannot achieve good hardness due to the big mass-effect. Also, it is not easy to reduce distortion of gears during heat treatment.
Austempering heat treatments
(austenitizing followed by rapid cooling
to the tempering temperature) have been
applied to nodular irons on an experimental basis for a number of years, but commercial interest in the process has
only recently come to the surface.
