This paper introduces new process developments in low-pressure carburizing and carbonitriding using either high-pressure gas quenching or
interrupted gas quenching.
When Belgium-based Hansen Transmissions was under the ownership of Invensys plc in the late 1990s, the parent company was dropping not-so-subtle hints that the industrial gearbox manufacturer was not part of its long-term plans. Yet Hansen’s CEO Ivan Brems never dreamed that, less than a decade later, he would be working for an Indian company.
