Gear Technology recently had the opportunity to sit down with Thomas White, Marketing Manager for Northern Technologies International Corporation, whose ZERUST line of corrosion prevention solutions includes specialized packaging, testing and comprehensive corrosion management services.
Oelheld US will be located in Booth #237475 in the North Hall. Oelheld technical experts will be on hand to discuss grinding, erosion, precision machining, and filtration, among other topics.
Many see the fluids as an unnecessary evil to the grinding process, failing to realize that selecting the right grinding fluid can lead to significant improvements in cycle time, surface quality, finishes, secondary operations, such as tool coatings. Oelheld has put together a short article on grinding oil considerations.
A reader asks: While I have read a reasonable amount of the literature on the pros and cons of anti-wear and anti-scuff additives, I find that the more I read, the more confused I become. I could use some clarity in my life.
