A study was performed to evaluate fault detection effectiveness as applied to gear-tooth pitting-fatigue damage. Vibration and oil-debris monitoring (ODM) data were gathered from 24 sets
of spur pinion and face gears run
during a previous endurance evaluation
study.
Micropitting has become a major concern in certain classes of industrial gear applications, especially wind power and other relatively highly loaded, somewhat slow-speed applications, where carburized gears are used to facilitate maximum load capacity in a compact package. While by itself the appearance of micropitting does not generally cause
much perturbation in the overall operation of a gear system, the ultimate
consequences of a micropitting failure
can, and frequently are, much more
catastrophic.
The powder metal (P/M) process is making inroads in automotive transmission applications due to substantially lower costs of P/M-steel components for high-volume production, as compared to wrought or forged steel parts. Although P/M gears are increasingly used in powered hand tools, gear pumps and as accessory components in automotive transmissions, P/M-steel gears are currently in
limited use in vehicle transmission applications. The primary objective of this project was to develop high-strength P/M-steel gears with bending fatigue, impact resistance and pitting fatigue performance
equivalent to current wrought steel gears.
In the hypercompetitive race to increase automobile efficiency,
Metaldyne has been developing its balance shaft module line with Victrex
PEEK polymer in place of metal gears.
The collaborative product development
resulted in significant reductions in
inertia, weight and power consumption,
as well as improvement in noise, vibration and harshness (NVH) performance.
