Read the Label Carefully May 29, 2018 Charles D. Schultz No Comments So, what exactly do we mean when we say “use good material” for your gears? Once again, the answer is “it depends.” Even the “best” steel may be wr...Read More
The Right Stuff May 24, 2018 Charles D. Schultz No Comments Even the most brilliant gear design will fail if the wrong material is used to make the parts. Our understanding of metallurgy and alloying element...Read More
That X Factor May 3, 2018 Charles D. Schultz No Comments Our international readers are no doubt chuckling over this silly, American “long addendum” terminology. The “civilized world” has long relied on a ...Read More
Moderation Instead of Modification April 12, 2018 Charles D. Schultz No Comments Few designers would feel comfortable with a face to pinion pitch diameter ratio of 2.00 anymore. Some still prefer to select face width by face con...Read More
How Much Helix Angle? April 3, 2018 Charles D. Schultz No Comments The most obvious difference between a spur gear and a helical gear is the presence of that “helix” angle. Civilians will call them “straight-cut” a...Read More
Worm Basics - Part 2 March 22, 2018 Charles D. Schultz No Comments Continuing our discussion of the “least you need to know” about worm gearing: 5. Efficiency is highly variable for worms. If it is critical to y...Read More
What About Worms? March 15, 2018 Charles D. Schultz No Comments It is difficult to know where to start when writing about worm gears, because this market segment has defied “standardization” within the United St...Read More
Bevel Buzzwords March 13, 2018 Charles D. Schultz No Comments Does technical lingo confuse you? If so, welcome to the bevel gear sector and its special kind of hell. The same “system” that benefited from stand...Read More
Effect of Non-Metallic Inclusions on Bending Fatigue Performance in High Strength 4140 Steel March 1, 2018 Three samples of quenched and tempered 4140 steel, with varying levels of oxygen and sulfur, were submitted to a series of bending fatigue tests.Read More
IIoT Spotlight: The Job Shop February 12, 2018 Matthew Jaster As IIoT solutions become more readily available throughout the manufacturing sector, challenges continue when you start looking specifically at the...Read More
