There is an increasing significance of screw helical and worm gears that combine use of steel and plastics. This is shown by diverse and continuously rising use in the automotive and household appliance
industries. The increasing requirements for such gears can be
explained by the advantageous qualities of such a material combination in comparison with that of the traditional steel/bronze pairing.
and macropitting is examined.
The aim of our research is to clearly show the influence of defects on the bending fatigue strength of gear teeth. Carburized gears have many types of defects, such as non-martensitic layers, inclusions, tool marks, etc. It is well known that high strength gear teeth break from defects in their materials, so it’s important to know which defect limits the strength of a gear.
Where were you? We were hoping to see you here at Gear Expo. We were surprised that you didn't make it.
Anyway, we had a really good show, along with more than a hundred other leading companies in the gear industry
who exhibited this year.
