The manufacturing process to produce a gear essentially consist of: material selection, blank preshaping, tooth shaping, heat treatment, and final shaping. Only by carefully integrating of the various operations into a complete manufacturing system can an optimum gear be obtained. The final application of the gear will determine what strength characteristics will be required which subsequently determine the material and heat treatments.
Austempering heat treatments
(austenitizing followed by rapid cooling
to the tempering temperature) have been
applied to nodular irons on an experimental basis for a number of years, but commercial interest in the process has
only recently come to the surface.
