In the hypercompetitive race to increase automobile efficiency,
Metaldyne has been developing its balance shaft module line with Victrex
PEEK polymer in place of metal gears.
The collaborative product development
resulted in significant reductions in
inertia, weight and power consumption,
as well as improvement in noise, vibration and harshness (NVH) performance.
Custom Gear and Machine, Inc., of Roscoe, IL, recently purchased a Reishauer RZ400 gear grinder and, on one job, has seen the cycle time drop from 40 minutes to six minutes, according to Tim Rose, vice president
of manufacturing, who runs the business with co-owners Dave Patterson and Mike Rasmann.
The quality of molded plastic gears is typically judged by dimensional feature measurements only. This practice overlooks potential deficiencies in the molding process.
