The automotive industry is evolving. The trend toward more electromobility is also changing the way cars are being manufactured. In some cases, this has a serious impact, not only on automakers themselves, but also on suppliers. Jürgen Hechler, Global Application Engineering Leader at 3M, is nevertheless confident: "We expect the demand for high-precision abrasives to continue to grow, despite the discussion about electromobility." Among other things, 3M supplies the automotive industry with abrasives for machining gears and shafts.
A very important parameter when designing a gear pair is the maximum surface contact stress that exists between two gear teeth in mesh, as it affects surface fatigue (namely, pitting and wear) along with gear mesh losses. A lot of attention has been targeted to the determination of the maximum contact stress between gear teeth in mesh, resulting in many "different" formulas. Moreover, each of those formulas is applicable to a particular class of gears (e.g., hypoid, worm, spiroid, spiral bevel, or cylindrical - spur and helical). More recently, FEM (the finite element method) has been introduced to evaluate the contact stress between gear teeth. Presented below is a single methodology for evaluating the maximum contact stress that exists between gear teeth in mesh. The approach is independent of the gear tooth geometry (involute or cycloid) and valid for any gear type (i.e., hypoid, worm, spiroid, bevel and cylindrical).
the same heat of material
