In November, Gear Technology conducted
an anonymous survey of gear manufacturers. Invitations were sent by e-mail to thousands of individuals around the world. More than 300
individuals responded to the online survey, answering questions about their manufacturing operations and current challenges facing their businesses.
Gear flank breakage can be observed on edge zone-hardened gears. It occurs, for example, on bevel gears for water turbines, on spur gears for wind energy converters and on single- and double-helical gears for other industrial
applications.
I came back from Gear Expo in a pretty good mood, and judging by the smiles on the faces of exhibitors I saw, I'm not alone. In fact, the mood at Gear Expo 2011 was the best I've seen in recent memory.
This article describes some of the most important tests for prototypes conducted at Winergy AG during the product development process. It will demonstrate that the measurement results on the test rig for load distribution are in accordance with the turbine measurements.
