For centuries, Switzerland has been considered home to the greatest watchmakers in the world. Works of fine beauty and optimal precision have been the norm there seemingly forever.
Multiple possibilities are available to increase the transmissible power of girth gears. These solutions include: using a larger module, increasing of the gear diameter through the number of teeth, enlarging the face width, and increasing the hardness of the base material. The first three parameters are mostly limited by cutting machine capability. Module, outside diameter, and face width (for a cast gear) can theoretically be increased to infinity, but not the cutting machine dimensions. There are also practical limits with respect to the installation of very large diameter/large face width gears.
Oil-out conditions, or conditions
in which an aircraft is
operating without any oil in its
gearbox or transmission, are
devastating for an aircraft's
hardware. Even the sturdiest gears
usually can't last 30 minutes under such
conditions before they catastrophically
fail, and the whole system usually follows shortly after. That doesn't leave pilots with a whole lot of time to find a suitable location to land in the case of an oil-out emergency.
It's the New Year, and with it
comes the opportunity to take
a fresh look at your business
objectives. Because business development
is such a vital part of running a
company, I'd like to present some guidelines I have found beneficial for securing new work and new customers.
Gear Technology's annual State of the Gear Industry survey polls gear manufacturers
about the latest trends and opinions relating to the overall health of the gear industry.
For many of us, 2016 was a rough year - and the results of our annual State of the Gear Industry Survey show it. 40% of respondents indicated their companies
had cut staff, while only 27% indicated an increase in employment. Clearly, there have been widespread cutbacks.
