We know that for cylindrical gears we have the standard DIN 3964 for defining deviations of shaft center distance and shaft position tolerances of casings. And for bevel gears? Is there some specific standard for defining deviations of center distance and shaft position tolerances of casings (orthogonal shafts), as DIN 3964 do?
This paper relates specifically to gears that are finish ground and considered high speed per ANSI/AGMA 6011; meshing elements with PLVs (pitch line velocities) in excess of 35 m/s or rotational speeds greater than 4,500 rpm.
