Robotic machine tending, collaborative mobile robotics and other technologies for optimizing process efficiency and boosting productivity
August 30, 2022
At IMTS 2022, Stäubli Robotics will exhibit advanced robots used to help manufacturers meet new challenges and changing market demands across a range of industries worldwide. The company will present live demos recreating real-world applications in industrial manufacturing, with an emphasis on robotic machine tending.
Workholding solutions increase throughput which generates uptime because they greatly reduce setup and changeover times. Operators can change workpieces in a highly repeatable manner which significantly increases the quality of the finished part. The primary function of streamlining production is to develop a workholding solution that optimizes the machining of multiple parts at once while maintaining tight tolerances. Below you will find a cross-section of companies that will be showcasing their approach to workholding systems at IMTS from Sept. 12–17 at McCormick Place in Chicago.
I'm presuming that you'll be attending IMTS at McCormick Place, Chicago, September 11–17. I mean, why wouldn't you? If you’re reading this magazine, then you're somehow involved in the world of gear manufacturing, and whether you're a design engineer sitting at a computer every day, a machinist working on the shop floor or an inspector working in a quality control lab, you need to understand how gears are made to do your job well.
IMTS 2022 will host a variety of technologies that will set the tone for manufacturing innovation in the years to come. At the forefront is the integration of data for process control, providing outstanding solutions to manufacturers. Wenzel America and Nidec’s collaboration started with the mutual drive for serving their customer with excellence through data management.
Oelheld US will be located in Booth #237475 in the North Hall. Oelheld technical experts will be on hand to discuss grinding, erosion, precision machining, and filtration, among other topics.
Forming tools are expensive, often made from carbide and tool steel. Carbide grinding is often the first choice today because customer requirements have increased and continue to increase in terms of complexity, dimensional accuracy and reproducibility. Apart from that, production must also be significantly more economical.
IMTS visitors can experience live machining with the WFL M50 MILLTURN/3000 mm. The multifunctional turning-boring-milling center is designed for complete machining of complex chuck and shaft parts up to 670 mm swing over bed. Turning, milling, drilling, hobbing, shaping, gun drilling as well as ID machining can be performed under any angle of the tool.
Verisurf Software, Inc. will be demonstrating a universal approach to measurement and inspection at this year’s IMTS Show in Booth #133345. Verisurf software provides measurement and inspection workflows with inspection plans that can be created once and used across the manufacturing enterprise on any portable or fixed CMM.
