On a highway, a compact pick-up truck struggles to tow a 30-foot boat up a steep grade. Inside the pick-up, the owner curses himself. He saved money leasing a smaller truck but sees now that he really needed a bigger, pricier vehicle, one suitable for this job.
Gear manufacturers typically use plastic, steel or other metals to make their gears, but Andrew Shotts made his first gears out of sugar and chocolate.
