As a community, we gear engineers collaborate and share ideas to progress our collective capability. Technology progresses based on our efforts, and we have seen solid advances in the performance of our products as they become quieter, cheaper, more efficient, and more power dense. The pages of this magazine (past and present editions) are filled with examples where talented engineers have dug deeper into a subject using a more precise approach to a particular area concerning gear performance. The implied belief is always that greater precision (complexity) in the calculations brings greater accuracy (alignment with reality).
A calculation-based study of different variants with regard to contact ratio and tooth root geometry to compare the results from the 2019 version of ISO 6336 to the previous version, released in 2006.
Changes in the third edition of parts 1, 2, 3, 5 and 6 compared to the previous edition (from the year 2006 for parts 1, 2, 3, 6 and from the year 2003 for part 5).
20/20 is considered to be perfect vision, but the year 2020 outlook is quite obscure. We can view the current state of the PM industry through short-term, fear-tinted glasses or gain a clearer picture of long-range opportunities. Just like U.S. manufacturing in general, the PM industry has been impacted negatively by the pandemic.
A reader asks: I'd like to know about the different approaches and factors considered while determining the value of Ka in regards to the DIN 3990 and AGMA standards.
In this paper local tooth contact analysis and standard calculation are
used to determine the load capacity for the failure modes pitting,
tooth root breakage, micropitting, and tooth flank fracture; analogies
and differences between both approaches are shown. An example gearset is introduced to show the optimization potential that arises from using a combination of both methods. Difficulties in combining local approaches with standard methods are indicated. The example calculation demonstrates
a valid possibility to optimize the gear design by using local tooth contact analysis while satisfying the requirement of documenting the load carrying capacity by standard calculations.
To achieve the requested quality, most gears today are ground. The usual grinding process includes treating the gear flank but disengaging before reaching the root rounding area. If the gear is premanufactured with a tool without protuberance, then at the position where the grinding tool retracts from the flank a grinding notch in the tooth root area is produced. Such a notch may increase the bending stresses in the root area, thus reducing the strength rating.
