Capitalizing on a burgeoning new
technology where gears are of great import, the gear community gathered en masse at the American Wind Energy
Association’s Windpower Expo 2010.
Although typically considered a late bloomer in the call to wind energy arms, the United States is now the
number one wind power producer in the world with over 25,000 MW installed by the end of 2008, according to the Global Wind Energy Council in January 2009.
The global wind energy market has seen average growth rates of 28 percent over the last 10 years, according to the Global Wind Energy Council (GWEC), creating major challenges for the component supply industry. GWEC also forecasts an average growth rate of 22 percent for the next five years, which if realized, will continue to put pressure on suppliers of turbine components.
Getting rid of personal mementos is an arduous housekeeping ritual for some
of us; every last gear has a memory. One man’s trash is another man’s gold, after all, or in some cases, one failed business is a forgotten piece of personal and mechanical genealogy. Such is the case of the Hill-Climber chainless bicycle, the remains of which were pulled from a family junk pile after nearly half a century.
Beveloid gears are used to accommodate a small shaft angle. The manufacturing technology used for beveloid gearing
is a special setup of cylindrical gear cutting and grinding machines. A new development, the so-called Hypoloid
gearing, addresses the desire of gear manufacturers for more freedoms. Hypoloid gear sets can realize shaft angles between zero and 20° and at the same time, allow a second shaft angle (or an offset) in space that provides the freedom to connect two points in space.
A computational fluid dynamics (CFD) method is adapted, validated and applied to spinning gear systems with emphasis on predicting windage losses.
Several spur gears and a disc are studied. The CFD simulations return good agreement with measured windage power loss.
Industrial gear standards have been used to support reliability through the specification of requirements for
design, manufacturing and verification.
The consensus development of an
international wind turbine gearbox
standard is an example where gear
products can be used in reliable
mechanical systems today. This has
been achieved through progressive
changes in gear technology, gear
design methods and the continual
development and refinement of gearbox
standards.
