Big gears and wind turbines go together like bees and honey, peas and carrots, bread and butter and—well, you
get the idea. Wind isn’t just big right now, it’s huge. The wind industry means tremendous things for the energy dependent world we live in and especially big things for gear
manufacturers and other beleaguered American industries.
It’s not too often a trade show so far
surpasses organizers’ expectations for
size that it must be relocated. This was just the dilemma the American Wind
Energy Association (AWEA) faced with the Windpower 2009 Conference and Exhibition, which was originally
scheduled to take place in Minneapolis,
but will now be held at McCormick
Place, Chicago.
