This article describes some of the most important tests for prototypes conducted at Winergy AG during the product development process. It will demonstrate that the measurement results on the test rig for load distribution are in accordance with the turbine measurements.
Gears with an asymmetric involute gear tooth form were analyzed to determine their bending and contact stresses
relative to symmetric involute gear tooth designs, which are representative of helicopter main-drive gears.
We talked energy efficiency with some
major players in the lubricants industry—
but with a focus on their products’
impact regarding energy efficiency of
gears and gearboxes in wind turbines.
Faithful Gear Technology readers may recall that our July 2009 issue contained an update of the deliberations
provided by Bill Bradley. Now, almost two years later, there is an ISO/IEC wind turbine gearbox standard out for draft international standard ballot (ballot closes 2011-05-17).
