The acceptance by discerning customers of passenger cars is dependent upon both the actual noise lever and the subjective noise character.
The subjective noise character itself can contain, among other features, undesirable noise phenomena which become apparent at certain points in the vehicle operating range. One such critical phenomenon is gear rattle, which is mainly present under low speed, high load conditions. Due to changes in the angular velocity of the crankshaft, gear rattle under driving conditions occurs at the unloaded gears and splines.
Resonant response
Dear Editor:
One of the hot items on the public agenda these days is "The Environment." Suddenly everyone wants to save the whales and the rain forest. Politicians, rock stars, and big business have all discovered that you can't get anything but good press for saying that you're in favor of trees and marine mammals.
