Gleasons Newest Threaded Wheel Grinder Delivers Faster Floor-to-Floor Times for Cylindrical Gears up to 300 mm February 13, 2007 The 300 TWG from Gleason Corp. is designed to deliver fast floor-to-floor times for grinding of cylindrical gears with a diameter up to 3...Read More
Ingersoll Cutting Tools Introduces Insert and Tooling Family February 7, 2007 Ingersoll Cutting Tools introduces its Hex-Turn family of inserts and holders. According to the companys press releaes, the 12...Read More
Cincinnati Machine Introduces CNC Tape Layer Technology February 6, 2007 Cincinnati Machine's new CHARGER Series of machines were designed to improve upon the technology and productivity of CNC composite ta...Read More
Rex Cuts Mounted Points Reach Deep Into Channels with Little Vibration February 6, 2007 A line of mounted available in various shapes and sizes to fit into channels and other contoured spaces for repairing and maintaining mol...Read More
Dapra Expands Toroid Tool Line January 26, 2007 Dapra Corporation recently added 12 new shell mills in ODs from 2" through 8" to its high-performance Toroid cutting tool line. For m...Read More
GEARCALC Software Officially Released January 26, 2007 GEARCALC, a software program for sizing and rating cylindrical gears, now offers demos for downloading. Three parts offer algorithms ...Read More
Hardinge Debuts Turning Center at Westec January 24, 2007 Hardinge introduces its SR-Series multi-tasking turning center, utilizing a three-jaw chuck. According to the companys press re...Read More
Inductoheats Heat Treating System Compatible with Numerous Power Supplies January 16, 2007 The InductoScan modular heat treat system from Inductoheat is designed to increase versatility, reduce maintenance and installation cost...Read More
Marposs Announces Plans to Release New Probing System at WESTEC January 16, 2007 Marposs Corp. will showcase its new Mida E83 probing system with optical transmission for CNC machining centers and milling machines boot...Read More
Koepfers Versatile MZ 130 Provides Same-Setup Gear Hobbing and Worm Milling January 10, 2007 Koepfers MZ130 hobbing and worm milling CNC machine from Monnier + Zahner was designed with versatility and ease of use in mind. ...Read More
