EMAG VL 1 TWIN Lowers Unit Cost for Bevel Gears June 30, 2020 Bevel gears found in passenger vehicles are mass-produced. Supply companies produce these gears, essential for differentials, by the mill...Read More
Helios Introduces TM 1000-CNC Gear Deburring and Chamfering Machine June 29, 2020 Helios Gear Products has announced the latest technology improvement to its Tecnomacchine (“TM”) series of gear deburring and...Read More
Superior Abrasives Offers Surface Conditioning Belts June 25, 2020 Superior Abrasives, LLC introduces Shur-Brite Surface Conditioning Belts which feature an open structure to resist overheating, part disc...Read More
Solar Atmospheres Installs Vacuum Furnace that Eliminates Costly Helium June 24, 2020 Solar Atmospheres of Western PA is currently installing a new rapid quenching vacuum furnace that will ultimately eliminate the need for ...Read More
Seco/Warwick Delivers Two Vector Vacuum Furnaces for Aerospace Application June 23, 2020 Seco/Warwick Group has sold 2 vacuum furnaces for an aerospace application to one client in two locations: the USA and Singapore. The Gro...Read More
SMW Autoblok Offers Self-Centering Power Chuck June 22, 2020 SMW Autoblok recently introduced the SJL 6-jaw (2+2+2) equalizing and self-centering power chuck.Ideal for CNC machining applications, th...Read More
NUM Software Provides 'Off the Shelf' Solution for Non-Circular Grinding June 18, 2020 NUM provides manufacturers of CNC cylindrical grinding machines with an elegant means of adding non-circular grinding capabilities to the...Read More
Ingersoll Offers More Feed and Speed with HiPos-Plus Mills June 17, 2020 Ingersoll Cutting Tools introduces HiPos-Plus mills with a diverse range of cutter and insert selections. BOMT inserts offer 2X positive ...Read More
Siemens Digital Adds Modern Cloud PLM to Xcelerator Portfolio June 16, 2020 Siemens Digital Industries Software has announced Teamcenter X software, a new product lifecycle management (PLM) solution delivered as a...Read More
Big Kaiser Expands Jet-Through Hydraulic Chuck Line for 5-Axis Machining June 16, 2020 Big Kaiser expands its jet-through hydraulic chuck line to include the BCV interface and additional inch sizes.The HDC jet-through type h...Read More
