Grieve No. 852 Walk-In Oven Designed for Customer for Heat Treating and Baking Varnish June 30, 2017 No. 852 is an 850°F (454°C), high temperature walk-in oven from Grieve, currently used for heat treating and baking varnish at th...Read More
Solar Atmospheres Constructs Climate-Controlled Vacuum Heat Treat Environment June 29, 2017 After surviving one of the hottest and most humid summer seasons on record, Solar Atmospheres of Western PA decided to construct a climat...Read More
Ransohoff LeanDrum CF Washer Offers Energy Efficient High-Volume Cold Forming Solution June 28, 2017 Ransohoff, a division of Cleaning Technologies Group LLC, has introduced its LeanDrum CF Washer. This new platform provides an energy eff...Read More
Seco Tools PCBN Insert Grade Family Expanded with Four New Hard Turning Grades June 27, 2017 Seco Tools has expanded its family of PCBN insert grades to cover the entire spectrum of hard part turning applications. Using a new bimo...Read More
KISSsoft Software Introduces Options for Sizing Shaft Dimensions June 20, 2017 When defining dimensions for shafts, KISSsoft's software now provides options for sizing shaft dimensions with regard to strength, an...Read More
Oven Industries 5R6-900 Temperature Controller Model Offers Versatile Features June 19, 2017 Oven Industries now offers the Temperature Controller Model 5R6-900 for use in laboratories and temperature cycling applications. The dev...Read More
Nanol Lubricant Additive Prevents Hydrogen Embrittlement in Metals June 12, 2017 The Fraunhofer independent research institute has demonstrated that Nanol's lubricant additive has some completely new performance fe...Read More
Carbodeon NanoDiamond Enhanced Electroless Nickel Plating Maintains Benefits While Improving Adhesive Wear Resistance June 9, 2017 Nanodiamond material specialist Carbodeon has worked with metal finishing specialist CCT Plating to develop a new NanoDiamond enhanced el...Read More
Product News June 1, 2017 The complete Product News section from the June 2017 issue of Gear Technology, featuring the latest from Liebherr, Heller, Sandvik Coromant, Mahr and more.Read More
