Siemens Sinumerik Blackline Panels Enable Rapid Interaction With the User Interface July 22, 2015 The Sinumerik blackline panels OP 015 black and OP 019 black are a new generation of operator panels for the Sinumerik 840D sl CNC system...Read More
Birchwood Cold Presto Black Process Forms Non-Dimensional Coating Thickness of 0.5 Micron July 21, 2015 Birchwood Technologies now offers three mini systems for use in small batch metal finishing at low temperatures. Mini systems are designe...Read More
TDM Global Line Software Tailored to International Manufacturers With Global Production Sites July 20, 2015 TDM Systems recently announced it will launch its new software module, TDM Global Line. in early August. TDM Global Line is tailored to i...Read More
Index 'Bevel Gear Hobbing Package' Produces Gears With Tooth Height in a Module Range of 0.6 to 4 mm July 17, 2015 Index recently developed a “bevel gear hobbing” package, which consists of a control cycle and four Index cutter heads with m...Read More
Dillon 1018 CR Steel Full Grip Jaws Reduce Distortion and Provides More Friction July 16, 2015 Dillon Manufacturing recently introduced full grip jaws made of 1018 CR steel from 6" to 15" in diameter, with heights of 2&quo...Read More
Schunk Tendo Platinum Toolholder Balanced to G2.5 at 25,000 RPM July 14, 2015 Schunk recently introduced the new Tendo Platinum toolholder. Tendo Platinum offers improved brazing technology by using a brazing and ha...Read More
Cimcool Cimperial 861 Metalworking Fluid Increases Tool Life and Provides Superior Lubricity July 13, 2015 Cimcool recently announced the release of Cimperial 861 with InSol technology, a hybrid lubricity, semi-synthetic metalworking fluid, whi...Read More
Dayton DayLube Grease Designed to Maintain Viscosity After 100,000 Strokes July 9, 2015 Dayton Lamina recently introduced their DayLube high-performance nano-ceramic grease. The grease is designed to maintain its original vis...Read More
Grieve 1200°F Walk-in Oven Offers On-Site Heat Treating July 7, 2015 No. 901 is a 1200ºF (649ºC) electrically-heated walk-in oven from Grieve, currently used for heat treating at the customer&rsqu...Read More
Mitutoyo LEGEX 4 CNC Machine Provides High-Accuracy Measurements July 6, 2015 Mitutoyo America Corporation recently released the latest LEGEX CNC coordinate measuring machine (CMM). The LEGEX 4 delivers accuracy in ...Read More
