Walter USA Introduces Ceramic Inserts December 7, 2012 Walter USA, LLC has introduced a new series of ceramic inserts directed at machining high-temp alloys such as Inconel, Waspalloy and Stel...Read More
Grieve Offers High Temp, Walk In Oven December 6, 2012 No. 893 is an 850ºF, electrically-heated walk-in oven from Grieve, currently used for heat treating parts on rollout shelves at the ...Read More
Zoller Releases Collision Software Module December 3, 2012 Is there a user out there that has never experienced the following situation? Programmed nominal data does not comply with real, actual d...Read More
LMT Fette Focuses on Efficiency in Large Gears November 30, 2012 The market for large gear wheels is growing – in a great variety of industries: wind turbines, construction vehicles and ships need...Read More
Sunnen Bore Gages Offer Precise Hole Measurement November 29, 2012 Sunnen's PG Bore Gages take an intuitive approach to hole gaging with a mechanical design and speedometer-type scale for quick visual...Read More
Diehl Introduces EDM Blanks November 27, 2012 Diehl Steel has introduced Ready-Block EDM Blanks for EDM applications. The ready-to-use blanks are pre-hardened, squared and ground at D...Read More
Oerlikon Fairfield Highlights Drive Solutions at Bauma China 2012 November 26, 2012 Oerlikon Fairfield is participating in Bauma China 2012 at the Shanghai New International Expo Centre from November 27-30. Bauma China is...Read More
Hudapack Selects AFC Holcroft Furnace Line November 20, 2012 Hudapack Metal Treating, a commercial heat treating operation with multiple locations in the Midwest, has selected AFC-Holcroft of Wixom,...Read More
Emuge Introduces Top Cut End Mills November 19, 2012 Emuge Corp. has introduced Top Cut, a new series of high performance carbide end mills. Offered in a wide range of metric and inch sizes,...Read More
Ipsen Ships MetalMaster Furnaces November 16, 2012 Two MetalMaster furnaces were shipped to U.S. customers – a commercial heat treater and a heat exchanger manufacturer. Both furnace...Read More
