Emuge Corp. to Introduce High Performance Tap June 17, 2010 Emuge Corp. will display MultiTAP, the industry's first high performance tap designed to cut a wide range of materials including carb...Read More
Supertec to Present Seven New Grinding Machines at IMTS June 16, 2010 Supertec Machinery will exhibit seven new grinding machine models/types at this year's IMTS. They will be located in the Grinding Pav...Read More
Sandvik Coromant to Present Tooling Innovation at IMTS 2010 June 15, 2010 Under the theme "The Road to Success Starts Here," Sandvik Coromant will be showcasing a broad range of tools at IMTS 2010. Wit...Read More
Techno Offers CNC Teaching Aid June 14, 2010 Techno, Inc.'s Educational CNC Division recently introduced a new "Basic Manufacturing Skills: An Introduction to CNC Machining&...Read More
High-Speed Inserts Incorporate Through Coolant June 11, 2010 The Power-Feed+Mini high feed cutter from Ingersoll Cutting Tools features high-speed geometry with a double-sided, four-edge insert engi...Read More
Universal Holding Fixture Reduces Costs June 11, 2010 The Kostyrka Universal Holding Fixture (UHF) is a highly flexible chucking device that can be adapted to several hundred different indivi...Read More
Delcam Launching Next-Gen Software Version at IMTS June 9, 2010 Delcam will launch the 2011 version of its FeatureCAM CAM system at the IMTS exhibition in Chicago. The release will incorporate a more m...Read More
Honing Oil Offers Extended Service June 2, 2010 Sunnen meets contemporary needs for planet friendly industrial consumables with the introduction of SHO-500, a long-lived general-purpose...Read More
Rex-Cut Designs Compact Bur Kits June 2, 2010 Three new carbide bur kits that are designed for specific tasks and come packaged in metal storage boxes to fit into a machinist's to...Read More
Touch Trigger Probe Increases Measurement Throughput June 2, 2010 Renishaw's new PH20 probe head increases touch-trigger CMM inspection throughput up to three times using fast, infinite, rotary posit...Read More
