Solar Awarded Order for R&D Vacuum Carburizing Furnace June 8, 2009 A top loading model VTC-714 R&D furnace by Solar Atmospheres was ordered by a mid-Atlantic, aircraft industry manufacturer for proces...Read More
Product News June 1, 2009 The complete product news section from the June 2009 issue of Gear Technology.Read More
Low-Foaming Cutting Fluid Resists Bacterial, Fungal Growth May 8, 2009 The KoolRite 2365 semi-synthetic cutting fluid from JTM Products, Inc. was designed for high-pressure applications that typically have fo...Read More
Product News May 1, 2009 The complete Product News section from the May 2009 issue of Gear Technology.Read More
Slender Drive Angle Head Machines Bores More Flexibly April 23, 2009 BIG Kaiser's Slender Drive Angle Head features a reduced body that is capable of 90-degree cutting operations inside small bores. The...Read More
Economy Tooling Line Creates an Affordable Start for Novice Router Users April 14, 2009 Techno, Inc. CNC Cutting Tools has announced the start of an economy tooling line of CNC router bits for use by novice CNC router users t...Read More
Face Mill Withstands Heavy-Duty Operations April 13, 2009 The CoroMill 360 from Sandvik Coromant is a 60-degree face mill constructed with through-hardened steel for strength in demanding applica...Read More
Electrically-Heated Quench Tank Cures Products Post Heat-Treat April 6, 2009 The Number 974 insulated quench tank from the Grieve Corporation is electrically-heated to 200 degrees for heating mineral oil to cure me...Read More
Modultherm Expands Capacity April 3, 2009 ALD and ALD-Holcroft Vacuum Technologies introduced a larger size of the ModulTherm vacuum heat treating system. The ModulTherm can now p...Read More
Coating Technology Extends Tool Life without Cutting Oil April 2, 2009 Mitsubishi Heavy Industries, Ltd. has developed a thin-film coating for applying to precision cutting tool surfaces to extend tool life a...Read More
