The automotive industry is evolving. The trend toward more electromobility is also changing the way cars are being manufactured. In some cases, this has a serious impact, not only on automakers themselves, but also on suppliers. Jürgen Hechler, Global Application Engineering Leader at 3M, is nevertheless confident: "We expect the demand for high-precision abrasives to continue to grow, despite the discussion about electromobility." Among other things, 3M supplies the automotive industry with abrasives for machining gears and shafts.
SMW Autoblok presents the BB-FZA2G pneumatic 3+3 sequencing air chuck featuring an extended stroke clamping range and three self-centering jaws with axial adjustment.
With its brand-new 300GMS nano Gear Metrology System, Gleason presents a world- first at Control Show 2022, May 03-06, Stuttgart, Germany. The capability of measuring gears at sub-micron level, executing advanced waviness analysis and evaluating gear noise using the most advanced analytical tools, make the 300GMS nano ideally suited to support automotive e-drive production with minimum noise requirements.
Manufacturers who look for versatility and precision in machining can pair up Seco Turbo 16 square shoulder milling cutters and Helical Turbo 16 milling cutters to reduce tooling inventories and costs. Both series offer high material removal rates in steel, stainless steel, cast iron, non-ferrous metals, superalloys and titanium.
At Automate 2022, attendees will have the opportunity to experience how complete, end-to-end automation solutions from KUKA Robotics can help them exceed their production goals.
Weiler Abrasives has announced the availability of its Tiger abrasives line designed to deliver maximum performance in the most demanding foundry applications. With solutions to address all grinding applications in the cleaning room, Tiger products help decrease cycle times and improve operator experience.
The Kapp Niles KX 300 P gear center offers machining flexibility due to various machining processes. The machine features direct drives in both the tool and workpiece spindles.
Many see the fluids as an unnecessary evil to the grinding process, failing to realize that selecting the right grinding fluid can lead to significant improvements in cycle time, surface quality, finishes, secondary operations, such as tool coatings. Oelheld has put together a short article on grinding oil considerations.
