Midwest Motion Introduces New Gearmotor July 19, 2007 Midwest Motion Products released a new DC Gear Motor, the Model No. MMP TM55-24V GP52-124. Accepting any 24 Volt DC source, includin...Read More
Marposs Introduces Wireless Bore Gauge with Optional Inductive Battery Charger July 19, 2007 Marposs Corp. will present its new M1 Wave wireless bore gauge with an optional inductive battery charger in at South-Tec 2007.Equi...Read More
LMC Workholding Offers Large Size Chuck July 11, 2007 LMC Workholding offers large size power chucks for high-speed applications and extra large thru-holes for large bore lathes. LMC of...Read More
Hainbuch Produces Large Mandrel With Significant Clamping Range for China July 9, 2007 Hainbuch GmbH produced a workholder that weights 1.3 tons and features a clamping range of up to 420 mm.According to the company's pr...Read More
Weiler Publishes Brochure Detailing Gear Deburring Capabilities July 9, 2007 Weiler Corp.'s six-page technical brochure on gear deburring with power brushes explains the importance of deburring ...Read More
mG miniGears Installs Furnace Loading System June 25, 2007 mG miniGears installed a furnace loading system in its powder metal department to avoid defects, especially for gears where small damage of the... Read More
Zeitlauf's Angular Gearing Offers Worm Gear Drive/Bevel Spur Gear Alternative June 21, 2007 The EtaCrown concept from Zeitlauf offers an energy-efficient alternative to worm gear drives and bevel spur gears.According to the compa...Read More
Brevini's Gearbox Operates Quietly for Rubber Sheeting Manufacturer June 21, 2007 When Primasil, a U.K.-based independent silicone compounder and manufacturer of non-silicone rubber sheeting, discovered its main drive g...Read More
Kapp's Rotor Grinding Technology Improves Efficiency by 30 Percent June 15, 2007 The Kapp RX 59 allows the rotors used in air compressors to be manufactured on the machines by using a high precision grinding process.Ro...Read More
Gearmotors Built for High Torque Applications June 6, 2007 The AKM gearmotors set from Heason Technologies combines the torque density from the company's line of servomotors with its planetary...Read More
