Drake's Newest Thread Grinder Utilizes Robot Load-Unload System July 1, 2006 The GS:TE-LM thread grinder from Drake Manufacturing is fitted with a robot load/unload system that provides maximum throughput for high-volume production of ground threads.Read More
Royal Purple Develops High Performance Worm Gear Oils May 1, 2006 Royal Purple developed a para-synthetic Synergy Worm Gear Oil and a fully synthetic Thermyl-Glyde Worm Gear Oil. Both contain slippery...Read More
Sandvik Introduces Next Generation of Insert Grades May 1, 2006 The GC1030, GC4240 and GC4225 from Sandvik Coromant were designed to enhance productivity in steel milling operations. The GC1030 and ...Read More
New Gearhead from Boston Gear May 1, 2006 New gearheads from Boston Gear are designed for direct attachment to popular servo and stepper motors. These durable, long-lasting perfor...Read More
New Checker Scan-Measures Stick Blades with Ruby-Tipped Probes May 1, 2006 This month, German automakers will receive the first three units of Klingelnberg's new automated blade checker designed for the shop floor.Read More
Gleason's Genesis 130SV Gear Shaving Machine May 1, 2006 The 130SV shaving machine from Gleason is the newest of the company's Genesis family of gear production equipment.Read More
Sterling Instruments New Precision Internal Gears Selectable by Inches or Millimeters April 30, 2006 New precision internal gears from Sterling Instrument are available from stock in inch and metric sizes. The 20? pressure angle inch ...Read More
Nireco America Introduces Geared Dancer Roll Potentiometer April 29, 2006 Nireco America Corp. introduced the Series 2699 geared dancer roll potentiometer. The heavy duty, high precision geared potentiometer is ...Read More
Rex-Cut?s Fiber Mounted Points Line Reveals Fresh Abrasives April 27, 2006 New cotton-fiber mounted points from Rex-Cut Products expose fresh abrasives as they work to deburr and finish in one step with chatter-f...Read More
