New Wireless Spindle Probe from Marposs January 28, 2005 The new Mida TT30 touch-trigger spindle probe from Marposs Corp. incorporates high-frequency signal transmissiom. Additional features ...Read More
Saint-Gobain Gaskets Seal in Temperature Extremes January 19, 2005 The OmniGasket from Saint-Gobain is constructed with a layer of PTFE adhered to an alloy base.According to the company's press releas...Read More
Donner + Pfister Introduces New Measuring Equipment January 19, 2005 The ES 4100 portable pitch measuring instrument from Donner + Pfister offers measuring data. Operational convenience is achieved by the b...Read More
Hexagon Metrology Debuts CNC Measuring Arm at Fabtech January 19, 2005 Hexagon Metrology introduced a new CNC articulated measuring arm at Fabtech that president and CEO William Gruber calls ?our version of a...Read More
Midwest Motion Gearmotor Accepts 12-Volt DC Sources January 19, 2005 The Model No. MMP-TM55-12V GP52-022 DC gear motor from Midwest Motion can accept any 12-volt DC source, including battery power, says the...Read More
New Retoolable Manual Bench for Gear Inspection from Marposs January 15, 2005 The new M62 OBD (over ball diameter) retoolable manual bench measuring system for checkng gear shafts from Marposs is designed to permit ...Read More
New Series of Bevel Gear Operators from Flowserve January 6, 2005 The Limitorque Actuation System MT Series of bevel gear opeators from Flowserve are optimized to perform in power industry valve applicat...Read More
New DC Gearmotor from Midwest Motion January 6, 2005 A new DC gearmotor, Model No. MMP.TM55-24V.GP52-100.1 can accept any 24 volt source, including battery power. According to the compan...Read More
New Sulfide Material from Ticona Makes Braking Easier January 4, 2005 Fortron linear polyphenylene sulfide (PPS) for actuator housings and gears to help transfer power from the actuator motor to the brakes. ...Read More
New Axle Shaft Hardening Capability from Inductoheat January 4, 2005 The VSM-95 vertical scanning machine from Inductoheat is tooled up to process axle shafts. According to the companys press rele...Read More
