A key part of gear design software development is customer feedback. With the right feedback, you can get your software developer to work for you to provide the most relevant features possible.
The 2017 Gear Technology Buyers Guide
was compiled to provide you with a
handy resource containing the contact
information for significant suppliers of
machinery, tooling, supplies and services
used in gear manufacturing.
Base oils play an important role in determining the performance of an industrial gear oil. They influence characteristics such as low temperature performance,
biodegradability, energy efficiency and high temperature thermal and oxidative stability.
First, the facts: powder metallurgy is a cost-effective method of forming precision net-shape metal components that allows for more efficiently designed products. It saves valuable raw materials through recycling and the elimination of costly secondary-machining. PM competes with wrought steel gears as the technology continues to advance. You'll find PM components in everything from automobile transmissions to aircraft turbine engines, surgical equipment and power tools.
Design and manufacture of gears is among the most complex and difficult disciplines of the industrial arts. From initial conception to machining and
finishing, making gears ain't bean-bag. And guess what? Once those gears roll off the assembly line, it doesn't get any simpler. That's because gears - the metal ones at least - require the correct lubrication in order to prevent - or delay as long as possible - such things as wear, scuffing and Hertzian fatigue.
