In this study, limiting values for the load-carrying-capacity of fine-module gears within the module range 0.3–1.0 mm were determined and evaluated by comprehensive, experimental investigations that employed technical, manufacturing and material influence parameters.
This article provides an overview of the benefits of using psychoacoustic characteristics for describing gear
noise. And with that, human hearing and the most important psychoacoustic values are introduced. Finally, results
of noise tests with different gear sets aree presented. The tests are the basis for a correlation analysis between psychoacoustic values and gear characteristics.
Super-reduction hypoid gears (SRH) are
bevel worm gears with certain differences regarding hypoid gears. If two axes are positioned in space and the task is to transmit motion and torque between them using some kind of gears with a ratio above 5 and even
higher than 50, the following cases are commonly known. Tribology Aspects in Angular Transmission Systems, Part VIII.
Hypoid gears are the paragon of gearing. To establish line contact between the pitches in hypoid gears, the kinematically correct pitch surfaces have to be determined based on
the axoids. In cylindrical and bevel gears, the axoids are identical to the pitch surfaces and their diameter or cone angle can be calculated simply by using the knowledge about number of teeth and module or ratio and shaft angle. In hypoid gears, a rather complex approach is required to find the location of the teeth—even before any information about flank form can
be considered. This article is part seven of an eight-part series on the tribology aspects of angular gear drives.
Gears with an asymmetric involute gear tooth form were analyzed to determine their bending and contact stresses
relative to symmetric involute gear tooth designs, which are representative of helicopter main-drive gears.
The objective of this study was to investigate the limits concerning possible reduction of lubricant quantity in gears that could be tolerated without detrimental effects on their load carrying capacity.
Beveloids are helical gears with nonparallel shafts, with shaft angles generally between 5 degrees and 15 degrees. This is part VI in the Tribology Aspects in Angular Transmission Systems Series
