properties.
Hobs, broaches, shaper cutters,
shaver cutters, milling cutters,
and bevel cutters used in the
manufacture of gears are commonly
made of high speed steel. These specialized gear cutting tools often require properties, such as toughness or manufacturability, that are difficult to achieve with carbide, despite the developments in carbide cutting tools for end mills, milling cutters, and tool inserts.
There is an increasing significance of screw helical and worm gears that combine use of steel and plastics. This is shown by diverse and continuously rising use in the automotive and household appliance
industries. The increasing requirements for such gears can be
explained by the advantageous qualities of such a material combination in comparison with that of the traditional steel/bronze pairing.
and macropitting is examined.
Companies around the world are learning to embrace the environment, and the gear industry is no exception. This special section takes a look at how some gear manufacturers are doing
their part to conserve resources, preserve and protect the environment, and give back to the land. What we’ve found is that adopting environmental
measures is far more than just good
corporate citizenship. For many gear industry companies, good environmental practices also turn out to be good for the bottom line.
For a high-speed gearbox, an important part of power losses is due to the mesh. A global estimation is not possible and an analytical approach is necessary with evaluations of three different origins of power losses: friction in mesh contact, gear windage and pumping effect between teeth.
