New turnkey, "off-the-shelf" Gleason 2700AR system automates larger-gear load/unload to speed throughput, optimize process flow - and take the weight off the operator.
Large bevel gears drive the crushing machines used to process ores and minerals in the hard-rock mining and aggregates industries. This paper is intended to help the reader understand the unique aspects of these machines, and why crushing applications fall outside the traditional automotive paradigm for bevel gears.
Historically, gearbox original equipment manufacturers (OEMs) and repair organizations have tended to offer their customers no-load, full speed (spin) tests as a standard performance test. If a load test was specified, the supplier would probably offer a locked torque back-to-back simulated load test, which requires a large investment in tooling to connect shafts of the test and slave gearboxes.
For this year’s exercise in large gears, we’re not going to dwell on size range or length, merely look at the fundamental challenges and latest technologies required to manufacture large parts in the gear industry. This could be a gearbox assembly for the construction, mining or oil and gas industries or simply a large standalone gear pinion set for a custom application. Whatever the industry or application, large gears require more preparation, planning and precision than other areas of gear manufacturing.
Business is finally starting to get back to usual in the big gear world, which offers us a chance to look back at the greatest lesson on how to survive an economic downturn. Includes the sidebar: "Brass Tacks with Klingelnberg."
