Speedy delivery of high quality, open die forgings, seamless and contoured rolled rings, and complex forged parts is essential to the growing wind energy sector
Specialty forgers can manufacture custom, high-quality, seamless rolled rings in a variety of materials and finishes in as little as eight weeks. Open die forgings and seamless rolled rings are essential components in the wind energy sector, contributing to the overall reliability and efficiency of turbines, generator systems, and transmission and distribution equipment.
The Forging Industry Association’s (FIA) Forge Fair, North America’s largest event dedicated exclusively to the forging industry, returned to the Huntington Convention Center in Cleveland, Ohio, May 23–25, 2023. More than 2,000 forging professionals from across the globe attended Forge Fair to learn about new products, make purchasing decisions, and network with each other. This specialized-industry event offered suppliers and forgers a platform to connect with more qualified potential customers. From material selection to the shipment of finished parts, Forge Fair showcased innovations in heating, tooling, equipment, testing, automation, conservation of resources, process and plant improvements, and technology for all types of forging operations.
Business is finally starting to get back to usual in the big gear world, which offers us a chance to look back at the greatest lesson on how to survive an economic downturn. Includes the sidebar: "Brass Tacks with Klingelnberg."
Near-net gear forging today is producing longer life gears at significantly lower costs than traditional manufacturing techniques. Advances in forging equipment, controls and die-making capability have been combined to produce commercially viable near-net-shape gears in diameters up to 17" with minimum stock allowances. These forged gears require only minimal finishing to meet part tolerance specifications.
Traditional methods of manufacturing precision gears usually employ either hobbing or shaper cutting. Both of these processes rely upon generating the conjugate tooth form by moving the work-piece in a precise relation to the tool. Recently, attention has been given to forming gear teeth in a single step. Advantages to such a process include reduced production time, material savings, and improved performance characteristics. Drawbacks include complicated tool designs, non-uniformity of gears produced throughout the life of the tooling, and lengthy development times.
