Gearbox Design: Refining the Study Layout August 21, 2018 Charles D. Schultz No Comments A critical step in designing a gearbox is refining the “study layout” and securing the necessary approvals so that detail design can begin. Althoug...Read More
Finding the Right Combination August 14, 2018 Charles D. Schultz No Comments One of the hal...Read More
Hardenability 101 June 5, 2018 Charles D. Schultz No Comments Material Grade in Gears The reason not all gears can be made from the same material grade has to do with hardenability. We have long unde...Read More
Moderation Instead of Modification April 12, 2018 Charles D. Schultz No Comments Few designers would feel comfortable with a face to pinion pitch diameter ratio of 2.00 anymore. Some still prefer to select face width by face con...Read More
How Much Helix Angle? April 3, 2018 Charles D. Schultz No Comments The most obvious difference between a spur gear and a helical gear is the presence of that “helix” angle. Civilians will call them “straight-cut” a...Read More
Worm Basics - Part 2 March 22, 2018 Charles D. Schultz No Comments Continuing our discussion of the “least you need to know” about worm gearing: 5. Efficiency is highly variable for worms. If it is critical to y...Read More
Nothing Remains Constant March 6, 2018 Charles D. Schultz No Comments We cannot leave our lesson about tooth depths without covering bevel gears. There is a tendency to think of bevels and worms as being best left to ...Read More
It Gets Complicated February 28, 2018 Charles D. Schultz No Comments Why did something as simple as a standard tooth form fail to get traction? While the old joke about the number of opinions at any meeting of engine...Read More
The Beginning of Wisdom January 11, 2018 Charles D. Schultz No Comments Faithful followers of this blog can complete that mantra without prompting, but for new readers — the beginning of wisdom is calling things by thei...Read More
