SKFs New Ball Bearings Reduce Noise in Air Handling Applications April 15, 2006 SKF? ConCentra ball bearing units for high-speed air handling applications integrate unique concentric locking technology to form a near ...Read More
Zero Maxs New Linear Actuators Convert Rotary Motion into Precise Linear Motion April 12, 2006 The Rohlix linear actuators from Zero-Max convert rotary motion to linear travel and carry loads at speeds up to 70" per second, de...Read More
NUMs Graphical and Conversational Software Compatible with Gear Manufacturing April 11, 2006 NUMs control systems will be displayed at IMTS and are suitable for use in gear manufacturing. The embedded machining cycles for ge...Read More
SKFs New Cylindrical Roller Bearings Extend Wind Turbine Gearbox Life April 11, 2006 New SKF high-capacity cylindrical roller bearings for wind turbine gearboxes have been engineered to promote longer gearbox service life...Read More
United Grinding?s Newest Machine Grinds Shafts and Chucked Workpieces April 11, 2006 [photo] The Studen S242 from United Grinding is designed for the hard turning and grinding of high-precision applications for both shaf...Read More
New Multi-Axis Machining Software from NCCS April 6, 2006 NCCS announces the new release of the latest version of NCL 9.5 that improves productivity by reducing both programming time and cycle ti...Read More
Bryan Grinder Releases New Software April 3, 2006 Bryant? Grinder, a division of Vermont Machine Tool, released Revelations? software, a Microsoft Windows-based, CNC control software that...Read More
Sterling Instruments Anti-Backlash Gears Eliminate Marred Shafts March 10, 2006 A new series of 1158 anti-backlash gears manufactured by Sterling Instruments feature the Fairloc integral hub fastening system, which el...Read More
Ikona Gear Launches Oil and Gas Division, Signs Licensing Agreements March 9, 2006 Ikona Gear launched Ikona Industries Corp. to focus on developing, manufacturing and shipping novel gearing applications for the oil and ...Read More
Detailed Computer Model of Gearbox Reduces Design Time March 1, 2006 LMS International helped a Fiat subsidiary develop a new, dynamic vibro-acoustic prediction method to reduce design time and engineering costs through accurate prediction of gear noise in the design phase.Read More
