Reduced component weight and ever-increasing power density require a gear design on the border area of material capacity. In order to exploit the potential offered by modern construction materials, calculation methods for component strength must rely on a deeper understanding of fracture and material mechanics in contrast to empirical-analytical approaches.
It is becoming increasingly apparent that material properties can and will play a greater role than before in addressing the challenges most transmission manufacturers are facing today. Making use of materials' intrinsic fatigue properties provides a new design tool to support the market changes taking place.
A reader wonders about gears where the tops of the teeth are the bearing surface, as used in spur gear differentials. Do they require any special construction or processing?
Which transmission system will come out on top is a hot topic in the automotive community. With multiple transmission-centric conferences on the horizon, there will be plenty of debate, but how much will the answer actually affect gear manufacturers, and when?
